DX5E means it has 5 channels as i'm sure you already know. Using a 6 channel receiver would only allow you to use 5 of the channels on it. If you need 6 channels then i'm afraid you need a 6 channel radio, unless you want two servo to work on one channel for something like ailerons on a plane using a Y cable.
Hope this helps.
