Can you see the marking I made on the carb that was much over 1/8th carb opening. my idle is where the arm is at right now. Now you can set this... Setting is done by trims. If you have done nitro before then you know.
Throttle hold needs to be off as the trims don't work on TH. on normal mode.. Throttle stick at zero.. (If you have a visual of the carb great, if not,) just use my pic as a kind of a scale, and set up the trim. Try counting an remembering so if by chance you bump it sometime you know where it goes.
After that, once you feel it's good, take a pic post it, and also during the same time , hot throttle hold, your throttle will go back to zero.
Now go to throttle curve settings and get to menu for hold, on the percentage , set it to say about 5percent. I click throttle hold from the switch see and feel if the servo twitches. See which way, increase or decrease the percentage to get it to not move at all at throttle hold set and release.
After that, add .5 percent to the throttle hold (cause Rhys where you'll start your engine) and it'll for sure start, and then it can idle on a bit lower carb when outside TH. .5% won't make a huge difference in Rpm but will definitely help start faster.
Go to setup menu and make sure that your throttle cut switch is enabled ... Try it, the button on top right and see of throttle goes all the way to zero no matter where it is.
Then before turning off the heli (just for test and test purpose only) out throttle all the way up or somewhere in the middle and turn off the TX. See if the throttle goes down all the way to idle or zero. If not we need to setup the failsafe by rebounding the rx to tx with all sticks at their respective zero positions.
Now your engine is the os-50 sx or sx-h?? You can recognize a sx-h as it has a big blue heat shrink head.
I see that you got this bird built? Do uou know ye condition of the engine? Compression as all?
Highly recommend unmounting the engine now and opening it all the way going over it in detail.
Let us know if you need help with that
