Good day everyone. Well, You have probably seen this series, but I wanted to put it on this forum. In this series, I will walk you through every single step that I went through to take apart, prep, paint, and even the backlight install. This is a rather long series, cause there are a lot of steps in the process. But, if you decide to do this, you will love the outcome. and yes, you can do this. It's not that hard. So, sit back, grab some and enjoy!
<object width="640" height="390"><param name="movie" value="http://www.youtube.com/v/qDIoH4Ig7lI?fs=1&hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/qDIoH4Ig7lI?fs=1&hl=en_US" type="application/x-shockwave-flash" width="640" height="390" allowscriptaccess="always" allowfullscreen="true"></embed></object>
In this episode, I walk you through taking out all of the electronics inside the case, and getting it ready to paint.
<object width="640" height="390"><param name="movie" value="http://www.youtube.com/v/BC1dQyw3Ln8?fs=1&hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/BC1dQyw3Ln8?fs=1&hl=en_US" type="application/x-shockwave-flash" width="640" height="390" allowscriptaccess="always" allowfullscreen="true"></embed></object>
In this episode, I go over all of the paint supplies and the different spray guns that I used to do all of the painting on this Transmitter.
<object width="640" height="390"><param name="movie" value="http://www.youtube.com/v/RBZvYarEDJo?fs=1&hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/RBZvYarEDJo?fs=1&hl=en_US" type="application/x-shockwave-flash" width="640" height="390" allowscriptaccess="always" allowfullscreen="true"></embed></object>
Here is Part 3. In this video, I prep the case, and put the black base on it. But, sadly I won't be able to keep it on there...
<object width="640" height="390"><param name="movie" value="http://www.youtube.com/v/Na8ey2mEQvI?fs=1&hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/Na8ey2mEQvI?fs=1&hl=en_US" type="application/x-shockwave-flash" width="640" height="390" allowscriptaccess="always" allowfullscreen="true"></embed></object>
Here in Part 4, I put down the primer, then the base color, and the clear.
<object width="640" height="390"><param name="movie" value="http://www.youtube.com/v/3zGtfkwkpUE?fs=1&hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/3zGtfkwkpUE?fs=1&hl=en_US" type="application/x-shockwave-flash" width="640" height="390" allowscriptaccess="always" allowfullscreen="true"></embed></object>
