Small trap I fell into with charging, using the "Y" cable supplied I charged a full used battery along with an half used battery.
Warning do not do it The half used battery puffed, obviously the charger did not register a full cell and kept charging until it had over charged the half full battery.
Hope this prevents others making the same mistake.
That charger should work just fine. But I believe the QX95 comes with 55mm props. If so, the 65's will not fit, they will hit the antenna on the transmitter.
Good Ole shaky Andy. That dude must drink a crap ton of coffee lmao. But yes, I have seen that and that is why I ordered a set of props that I thought would work, but didn't. They hit the camera. The only way to make them work is to move the camera to the left and tilt it back about 5º on my quad. But if you have the blunt nose props like he had, then you should be able to just shift the camera to the left a few MM and it should be fine.
