Well,the build is finished and I just need to wait for some calm weather for the maiden flight. Like your build Tony the plane is tail heavy when I tried to balance it at 1/3 of the wing chord. The battery is as far forward as it can go and the ESC is also well forward. I was going to go to a local tyre supplier tomorrow to get some adhesive tyre balancing weights to try and weight the nose down so I can move the battery back a bit. Other than this,is there any way of lightening the section after the wing to save adding weight to the nose. I was also thinking if I built this again of extending the fuselage forward of the wing by a couple of inches to try and balance it out better. What do you think?
