Hahahahahqhhahq well you might be right tony... Only one way to find out isnt it.. You gotta drive over here and check
Well the bird is having small teeny weeny issues here and there.
Spooling up on the bench the sensor would pick up rpm 300 more than set. (Esc was programmed on heli mode)
Also the stupid thing would respond really poorly to throttle changes and in some cases drop rpm to as low as 900 before picking it up and kept hunting.. Again, my esc was programmed for heli mode
The esc needed to be programmed in external governor mode for it to respond fast to the changing inputs. Which I didn't know, as I am new to this electric heli game..
When I changed that the esc won't arm. At all. No matter how low I made my low end point it just won't come alive.
Researched everywhere and somewhere hidden I found the info that if you have "external governor" setup selected, can't have "auto rotation " mode checked with it, or it just doesn't initialize, and there's no reason why that happens. Well... Alright gotta Go back and change the programming again
Went to plug in the esc to the batteries to connect it to the software, and ...... One of the ec5's on the esc decided to come off solder. Very glad it happened on the bench and not in the air but.... It frustrated me to death and I quit for the day .. This heli is hanging on the wall needing a solder job and reprogramming of esc. I had to stop and clean up.. Today I go to work, so couldn't leave the build mess out.. Or wife would have murdered me hahaha..
So yep I've had hiccups.. Lol
I have soldered so much in this build ESP when I got the esc ready for install before and then realized a recall, and then realized my connections were wrong, and then I had to add a YGE CAP 7 capacitor pack for the length of my wires was going to be above recommended 12" total.. And then the charging rig build... Was done with soldering for the weekend lol
Yeah... Have learned and discovered wayy to much.. And soldered abd re soldered too much too haha! That's why .. But just means that I am covering .. Or trying to cover all my bases before I go up.
So that's what's going on.. I am sure I am missing something still had a ton of hiccups .. Haha but that's expected ..
Fly safe!!
have fun!
