Now that is a case. Looks great.
Very nice indeed Rick. You will need handles on each end, so your wife can help you carry it to the park.
Jim
Looking really good![]()
That looks FANTASTIC! Your helicopter will be proud to ride around in that.![]()
These are cheap enough if you want D type rings. You can mount them with some nylon strap which can be found at a hardware store. But so can the rings. I'd prefer a metal mounting plate for them myself though.Hey Rick, the case is looking good. If your looking for rings for shoulder strap, might sound silly but try looking at the shower curtain rings. They have all size and styles.
That is what I ended up with from a local crafts store. I have a sheet of thin Al I hope to make a mounting plate with, it's pretty soft so it should work OK. I have a shoulder strap from an old gym bag.These are cheap enough if you want D type rings. You can mount them with some nylon strap which can be found at a hardware store. But so can the rings. I'd prefer a metal mounting plate for them myself though.
US Warehouse | 10pcs D Rings Ferrule Ribbon Clasp Knapsack Belt Buckle 15mm
