Slobberdog
You would have to have clearance built in to the machining, if the shaft is 6mm the hole can't be 6mm or you will not get it on, you need the internal dimension of a finished 6mm pinion, with tolerances being so close on heli's I don't know if I would trust it.
Kev........
Kev........
