D.O.G. if you are trying to isolate for vibration start removing moving parts. Remove the head and run the shaft by itself if that does not do it remove the tail boom. If that does not do it let me know I have an AR7300BX and an AR7200BX that I am not using at the moment that you can use to figure out if there is something wrong with yours. I am south of you in Riverview this is south of Brandon east of Tampa.
Thank you very much for the offer jcfernan51. Being in Riverview, you know how windy today and probably the next couple of days is going to be....So I'm in the process of elimination during this time. I do have AR7200BX on my Tarot 450 and my Gaui X3 . If i can't fine the vibration, then I will take one of them off and try it on the 500. The AR7300BX was on my Gaui and she flew great. After buying the 500 from a friend, I put the 7300 on it. I'm hoping it's not the AR.
Yesterday, I reset the TX/AR and my settings and started all over. I haven't had the chance to try it out because of the rain and wind. I probably won't be able to test flight her again today til the weather lets up. I did notice that my tail shaft bearings has a slight play in it. I do have a brand new tail assembly that I'm going to put on today. I do thank you for the offer jcfernan51
