holtneil
Hi guys , i have tested my new 500 pro more now wind has stopped and i have 2 very small problems , one is a tail kick when in a hover it acts like the gyro turns off and on again in a second so you get a tail kick, is it a power problem esc is set at 6v i can make it 7v ( its the standard castle 70amp that comes with trex 500 pro )
the second which i think will be easy to sort as you go from forward flight to a stop heli bounces , What gain do you adjust to stop this ?
All setting are as Tony said on the 3gx videos
