RCFashBashandCrashJUNO
HI, hope I am putting this in the right place now let me know if I am wrong again. I chatted with HK and they did not know.
I want to go off-road/mud/trail riding, TIRES & RIMS for my HK Bad Bug was Nitro circus you get more parts with Nitro Circus.
It is 1/16th scale RC and it is fast!!! Any ways this is what I found so far:
1st Specs:
Specs:
Length:325mm
Width:234mm
Height:160mm
Wheelbase:188mm
Ground clearance:52mm (adjustable)
Battery area:100mm x 18mm x 35mm
Motor size:2838 Brushless Inrunner
Motor:2800KV
ESC:35A
Servo:High Torque Metal Gear Steering Servo
Drive Train:Full-Time 4WD, twin differential
Internal Gear Ratio:5.58:1
Included:
1/16th scale Basher mini monster truck - Bad Bug
2.4ghz digital radio system
2nd
Features:
• Slipper clutch in the transmission and tougher transmission gears
• Stronger and longerdog bonesand outdrives
• Powerful 2800KV brushlessinrunnermotor (water resistant)
• 35A brushless ESC w/ reverse (water resistant)
• Metal gear high-torque steering servo (water resistant)
•Full time4WD
• Sealed front and rear differentials
• Alloy motormountplate
• Heavy dutydriveshafts
• Hardened metaldrivecups
• Full ball bearings
• Oil filled, threaded shock absorbers
• Adjustable toe-in and toe-out
• Adjustable camber and castor
• Independent wishbone suspension
• Front and rear metal suspension arm holder
• Pre-installed wheelie bar
• Extra alloy shock for wheelie support
NOW YHE HELP PLEASE!
Tire Set (L & R) (1 Set) - Basher 1/16 Mini SKU: 9249000954-0
Blade Count:
N/A
Diameter X(Inch):
No
SKU
9249000954-0
Watt Hour
0.00
Weight(g):
154.00
Length:
180.00
Width
50.00
Height
90.00
I would like Black Wheels pre-mounted ones. Any manufacturer just something that looks right and has aggressive tread and good quality! Set of 4.
Down the line I will get the Basher 1/16 4WD Mini Monster Truck V2 - HellSeeker (RTR)
SKU: 9249001251-0
I do have a micrometer if I need to meausher what you need to see, just tell me how.
1st Specs:
Specs:
Length:325mm
Width:234mm
Height:160mm
Wheelbase:188mm
Motor:2800KV
ESC:35A
Included:
2nd
Features:
•Full time4WD
Blade Count:
N/A
Diameter X(Inch):
No
SKU
9249000954-0
Watt Hour
0.00
Weight(g):
154.00
Length:
180.00
Width
50.00
Height
90.00
SKU: 9249001251-0
