yardner
Check it out !!! Went out and picked up this new DX8 ....
But i'm having problems with getting it set up.
1st i went and binded and set it up for my MCP-X. every thing went well and its flying well.
then i went and binded and set it up for my T Rex 450 Pro.
it took me a while but i got everything working (3GX ) servos, swash, pitch. 0* at mid stick went through whole DIR setup.
then i set up the 3GX and got everything set, gyro, tail gyro direction working properly.
??? But the tail aint right!!! Real Bad Tail wag.. as soon as i lift off the skids it starts getting the bad tail wag. used the same gyro settings that i used in the DX6, which were Gyro rate 65.0%
moved them down a little and no effect.!!!
did i do something wrong setting up the 3GX ? i thought that maybe i dialed in some sort of delay? but i just checked and its set for 450 size and don't think i added and kind of delay into it.
Or did i miss something in setting up the New DX8?
The Pots are set at ELE gain 110 / AIL gain 110
so what am i missing???
really like the DX8 but i'm kinda bumbed that i can't figure this out
Thanks,
Tony, sorry if this post is in the wrong Forum.
you can move it if you like. but the 450 forum is where a usually hang out at. Thanks
Thanks,
