trainrider06
Right news from the work shop,,,,,, she's ready I cannot adjust this anymore. Blade 1 0.01 Blade 2 0.00 @zero pitch, I have 10 + and 9.7 - pitch aileron 6.3 L 6.5 R.
Is there a way to measure pitch on the tail? and if so how do I do that and what would be the best to start with?
Sounds like you got it as close as it'll get.
Myself I have always just folded the tail blades, evened em up and called it good. If you want a slight pitch in blades then just have em a hair offset, not sure which way you'd need to go, probably if you wanted a bit of pre pitch in blades you'd have to do an adjustment then unfold blades, and see if the leading edge of the blades were pitched out, or in, not sure which way you'd want. You'd know on spool up though....
