Download an Align 450 v2, or pro manual, it will tell you.... I'm not sure myself...
trainrider06 Active Member Apr 29, 2015 #21 Download an Align 450 v2, or pro manual, it will tell you.... I'm not sure myself...
Tony Staff member Apr 29, 2015 #22 Yeah, get rid of that drill (sorry for the late reply), it's too much power. Also, get allen drivers and get that torx off of there. I own two sets of Align drivers, and they are great. As long as the bolts are not clone that is...
M makarthur New Member Apr 29, 2015 #23 First step: should be and must be study the manual, which can be found at http://www.arthurmak.hk/manual/Align_helicopters_450SEV2.pdf - - - Updated - - - http://www.arthurmak.hk/manual/Align_helicopters_450SEV2.pdf
Tony Staff member Apr 29, 2015 #24 It can also be found here. Second one down. http://www.rc-help.com/content.php?171-instruction-manuals
murankar Staff member Apr 29, 2015 #25 If you strip a bolt at the head you can cut a notch in the head with your dremel. Then with a regular head screw driver remove the bolt.
M makarthur New Member May 3, 2015 #26 Took down the rotor head, applied thread lock and install the flybar. Ensure flybar balanced. Reassembled rotor head - - - Updated - - - Tony, Yeah, ordered a Dremel, but still in transportation.
Tony Staff member May 12, 2015 #28 Looks like you are gettign there. Have you gotten any farther with it?
