gadget47
So I recently purchased a kraken 580 nitro, torque mini servos and an ikon 2 bt fbl setup. Flew 4 tanks and had the trims set- tank 5 brought with it a servo failure (pitch) and crash. After all was repaired/replaced i have been un able to dial in the tail response/gyro. Even went as far as replacing the tail servo again w no luck. The gyro setting doesn't hold- on the heli- and stays as programed in the ikon. Some damage has to have happened during the crash (ikon says unlikely) so I'm replacing it with the spektrum fc6250hx. I'm sure I'll be flying again with the new unit- ill keep a log of the 6250hx operation as I didn't find much info about it here. I understand ikon 2 has a good rap, but it can't be proven by my experience from the company or their product. Plenty of other mfg out there.
