Vincent Woudstra
Hi everyone,
Tonight I started on building the head of my alzrc devil 450 and was wondering whether I would run into the same problems Tony had in the build video.
It is not quite clear to see in the pictures, but the screw to fix the head to the main shaft is in exactly the same position as the one Tony build and where he later drilled a second hole, I believe 8mm higher.
I was wondering about the linkage length. I set the linkage length to the approximate 44,5 mm as stated in the manual, but now they are about as tight and short as they get.
Also in the pictures you can see the difference between the swashplate fully up and fully down and it is my understanding that I have only a little positive pitch and a lot of negative pitch this way.
swashplate up:
swashplate down:
So if I understand correctly I would need to lengthen the linkages quite a bit in order to correct this, am I right about this?
I'm not comfortable drilling in the head like Tony did, so I would like to avoid that if possible.
Also the shaft is not yet turning very smooth and also the swashplate is not moving very smooth up and down, so I guess I'll have to put some oil on the swashplate bearing and maybe also on the shaft, right?
Any advise is greatly appreciated since it is my very first build from scratch.
swashplate up:
swashplate down:
