trainrider06
Ok I decided to replace the main gear on my 500 TRex, the other one to me was questionable....
Two things I noticed (mind you this is a second hand 500 that I traded for) one the washer between the main gear and the tail drive gear was missing. I replaced it out of the screw kit I ordered from Align with the proper
washer. So I installed the gear, and noticed that the main gear seems to ride pretty high....and looking at the mesh between the main gear and pinon its riding high on my pinion...the main gear assembly seems to be kinda sloppy also. I have the correct washer also installed on the top bearing on the bearing block (top)
Am i missing something here? I checked out the manual, and the only 2 washers I see in the shaft/gear assembly are the one between main and drive gear and the one that rests on the top bearing block....something just doesn't seem right here....
