Update:
Got:
an MKS 95i servo (for my tail)
hb pp 50a v3 esc (better than the stock Align 35a)
a scorpion motor (but still using 3s)
and changed some parts like the feathering shaft and main. When I checked the main shaft I noticed I dont have the one-way shaft ring and dont even remember if I did got one before. It's the reason I crashed I think bec. during inverted(the only 3d I know) I have no control of the tail. Also checked the frame rate this time looking at the parameter(on my pc) to be safe and sure whether the frame rate value changes or not. Gathered and read all your replies again. Now it flies smooth except for a bit of tail shake which I have to adjust the gyro(hopefuly). Thank you for ALL your replies. I still have a lot to learn(from all of you).
