Servos mks hv9780
Sparse
ok so i took the ikon off my 450 to put on my 600. I put the 3gx back on the 450. with the ikon i can run mks all the way around, however when I hooked up the 3gx and went to set up the tail servo which is hv, there is no response. when a tx input is given. I did try my old align tail servo snd that works fine. does the 3gx not work with hv servos ? like I said the mks hv9780 works fine with my Ikon.
It should work without issue, just a little slower. Are you sure you had the polarity correct? Just checking, don't kill me :chuckles:
I don't know the methods of setting up a 3gx, but have you choosen the correct servo setting because the mks is 760μs / 560hz.
thanks guys the servo now works , the frame rate had to be change to 760. all is good now in the world of mks.:burnout:
I will get one up its been really cold here as of late in PA. did a test flight today and froze. have to dial in the 3gx a bit also. I knew I got the Ikon for a reason, but am saving that for my 600.
