Evening Smoggie, emailed SAB today about their new Kraken 570 for details, I will be getting one for test purposes to the one we have designed and just putting through its tests. if you jump out of a tree straight legged it breaks, bend your legs your body absorbs the shock we have started from feet up, I admire the design, agility of the apache heli, stealth bomber all taken from designs of nature the Bat, we have put together a total new concept, shock damped landing gear, which don't break off or stress the frame, total new carbon mixed kelvar frame 25 percent lower and 500 times stronger than current, full carbon Kevlar shell and tail, the tail boom is, how can I say diamond shape, matching the canopy and doesn't flex under any degree of force reversed the swash, put the motor at rear it is perfectly balanced, boom 15 percent shorter, all screws are titanium ,balanced titanium main gear shaft, shorter, new scoop and frame to protect the gyro and scoop keeps the motor 48 percent cooler. underneath canopy scoop keeps the electrics cooler because of its balance and its lighter it needs lower head speed longer running time, if it should fall it falls straight, detachable foam filled nose cone, the three of us are determined to build it half the price of the Kraken with more agility of the bat, the boom shape keeps the heli rock solid stable, we was all board in lock down spent 6 months on this project just for fun. to many things to list in its design and features we will be thorough testing it and making changes over the next six months
