Right on. However, because this is a momentary push button switch, and bail-out usually would require you to have the switch on until you are sure you have control, I would put the gear switch back there and use that switch. Wait, on a heli that switch does nothing... Okay, I would get a good switch like the others and use that. Just don't forget to turn it off when you turn your Tx off after binding lmao.
