ok so lets do this.. here are your head speed options when looking at it..
Here is your headspeed graph for a 14t Pinion:
Here is your headspeed graph at 15t pinion
Here is your headspeed graph at 16t pinion
Remember the efficiency of the motor is assumed at 90 percent.. and the "low voltage" is at 10.3 at a drained battery with may be 200 mah left.. so forget the low.. .. which is way lower than recommended.. you never wanna go less than 80 percent of 2200mah available to you.
So looking at this.. you have a 16t pinion you are looking at headspeed of 5500rpm! TOO HIGH for esp a beginner. Your bird will scream.. will be extremely twitchy on the sticks.. you will hate it starting off.. and then any crash will cost a LOT.. NOT recommended for someone who is new or starting off.
Now with my setup.. I get a headpseed of. 3700 rpm.. and is more than enough on what I can do.. or I will need.
Again adding to that.. I will wanna add that the higher headpseed will mean more bog in the motor as you will have lesser torque. The motor KV you are using.. is that a recomended motor? or something you picked out ? Check the manual and see what is recommended on this motor.. if this is a kit with a motor and pinion.. check their throttle curves. At too high of an rpm.. be it metal head or plastic.. tooo much load can disintegrate the head. or bend it.. So have to be a bit careful.. and add to that.. usually.. the tail runs (usually) 1:5 ratio.. so your tail will be going at 5500*5 = @_@ .. that means it wont be recommended to probably run any plastic blades but carbon blades.. as you can see.. things need to be taken care of..
I would aim for 3700-3800.. that in itself is higher rpm than a stock straight gear trex 450 pro will do.. ( I have helical with a lower gear ratio so I get 3700)
