Chargers My Charger :)
Slobberdog
Not sure how it will work with it connected that way, if you only wanted the 12v side on, so can't say much,
the way I have it you can run 12v or 24v or both, and it's only a little extra wiring and a second set of poles.
Graham Lawrie
I still have the second set of poles to fit:)
Next question: on the pins at the back do you do the same on both PSU,s ie 4 wires from each?
Graham Lawrie
Both options?
I will take some pics and post up:)
You will see mine is the same at the PSU out as yours, just mine are on their side due to space.
View attachment 10091 I have still to fit the 12v connectors on the left hand side
Just had a thought today!!
When putting two bullet connectors in place, should they be separated from each other(insulated) and not touching???
Graham Lawrie
OK I MIGHT HAVE HAD A EUREKA MOMENT?????
Can anyone tell me if the 12 pins on the back of the PSU just need jumpers? I think I remember Tony,s video mentioning this?
If this is the case, then it is as I said, I have been over thinking this build!!
And if I am right, then I know how to complete my charger:)
I have looked at Kevs and other builds and confused the heck out of myself, trying to put two + two and getting 3.14???
If someone could let me know, that would be great:)
Yes, you will only jump 4 of hte pins though, 3 are required, the 4th is to slow the fans down so it doesn't sound like there is a 747 in your house lmao.
You will jump the wires as shown in the diagram below. I just bent the 3 outside wires to the center wire and soldered them together. If you want a switch, you will run one switch from 8 to the switch, then two wires from the other side of the switch to 6 and 10. If you want to be able to adjust your fans, you can put a switch from 8 to 4. This will allow you to kick the fans on high if you want. You may be able to put a rheostat on there and adjust them infinitely.
Graham Lawrie
Bang goes the eureka moment:(
So both switches go to number 8 pin and the other two wires to 6 & 10 on both PSU,s?
What are the functions of 6,8,& 10?
I have switches to fit, so where do I short 4 to?
Yes, but I would NOT connect both grounds of both PSU's together. I would run a switch for EACH PSU for safety sake.
6 is PSKill and 10 is PSOn. I have no idea why PSKill has to be jumped to ground, but it does.
pin 4 will short to pin 8. This will slow the fans down and make them quiet. Trust me, you will want to do this. Again, you can put a switch here so you can shut the switch off (open the circuit) and it will kick the fans on high.
That would be a Gaba (Mr. Electrical Engineer) question lol. I'm not sure myself.
Stambo
It's probably something to do with it being a safety circuit.
While the motherboard is controlling it the fan does what it is told, the PSU knows all is well.
If something goes bad and it goes open circuit the fans go in to panic mode and scream at top speed.
Graham Lawrie
Is that jumped to the ground on the switch?
Slobberdog
Graham, pson and pskill go together on one side of the switch then the ground and the fan goes on the second, I think you on your switch will need a wire from the pson pskill side to the third leg for your led, can you put up a pic of the back of your switch, so we can see it.
