Phil,
How is the 700X coming along? The dealers here were having a Halloween sale and my remaining willpower crumbled, my 700X 'Super Combo' arrives on Tuesday
I got it complete with the BeastX Plus, but that will be going on eBay. I've got a spare Vbar Silverline which I'll use on the 700X. It will be interesting to compare build notes.
Steve
Hi Steve, nice one there! I doubt that there's much for me to help you with on your build and I'm sure it will be in the air long before mine.
It's funny you should ask about mine. I just got home from the shop and managed to do a bit more starting with the tail. First off, I did some work on my 550 after fitting a new tail rotor assembly. The blade holder assembly was showing some play and I reckon I could actually see it whilst hovering last time out. It's ready to go again now.
After that, I switched over to the same end of the 700X, my word, the tail rotor assembly is nice and shiny
It's all loose assembled, I prefer that after the 550 being all gunged up
Careful with the two larger screws, the two smaller ones on the yoke need to be out for access.
All screws glued up and the assembly ready to fit.
Next job the torque tube.
I left it to set after gluing the support bearings to the tube. The pieces of masking tape are located at the point of gluing.
Not much to do now and the air frame is ready. I'll leave the tail off as it's much easier to handle on the bench. I'll be visiting Hugo this week to order up the Axon and buy the receiver, Supra X connectors and anything else that takes my fancy I hope I can resist the urge to buy the Velos-Rotors 880
