Hi all, so returning to my thread...................
I'm of the opinion that it's ESSENTIAL to have more than two helis. They should relate to your current skills ( and, yes, needs
). My justification is simple, if you maintain them well and have the skill level so that crashes seldom occur, then the only limitation should be your bank balance and capability to supply them with enough batteries to keep them in the air. The last requirement is your time. I watched an amazing night flight on Facebook, so why not 24/7
I'm going to start my 700X build on Thursday when my good lady liberates the space for me in our workshop
On the 700 size, 5mm bullets. The Supra X bullets are better because they have a plastic shroud to protect from shorts where plain bullets like I'm using are quite vulnerable to shorts if you get careless for a moment.
Hi Steve, any photos you can publish showing your wiring arrangements and battery charging connections will be much appreciated. I'm holding off buying the Supra X connectors right now until things are a bit more clear for me. I'll probably wait until the air frame is completed before finalising on that.
Regarding the battery mounting............... my thinking is that back-2-back is a better arrangement as neither of the batteries are pressing against the wires but I've never been able to study multi-battery arrangements before other than in diagrams and they never seem to show enough detail.
