wolfman76
Well besides tony I don't think anyone else knows what happened to my beloved dx6i...Well about a 2-3 weeks ago let's just say a glass of sweet tea was knocked over and the rest i would assume you guys can guess what happened...Yup she got a bath!!! I quickly took my cherished tx apart and found that it was not as bad as originally thought it was going to be considering it was a 32oz. glass FULL glass that is.... As i was saying i quickly took it apart and found that there was hardly anything inside the case whew!!!! right.... Yeah that is what i said but when i part her back together and tried to turn it back on ...NOTHING!!! Well first step i have tested each battery each one tested at 1.27 volts ok they r a lil low but ok 5.08v all 4 together...I next tried tested if there was voltage after the power switch you would think it should also read 5.08v there also nope nuthin not a thing so obviously the problem is somewhere between the switch and the battery bay... iI am still checking to see if i connected a plug wrongly I don't think so but i will check anyways to atleast eliminate the possibility... only other 2 options after that is 1 come up with postage and let you tony try to work your magic n c if it something simple i just overlooked (fingers crossed) if you can get it working you the man tony.. Option 2 is tony is unable to work some magic is to call up horizon or spektrum or whoever it may be to send it in and have it tested to see how much it will cost to fix it... we will see how it goes hopefully it will turn out to be somthing simple... Onlt time will tell... let this saga begin.
