The 600 is finished with the help of my instructor.
One last thing I would like to do is add a separate RX battery. I prefer to power the electronics on their own rather than risk having the motor spool up on me. I'm going to use a JR connector from the RX to a 2s lipo battery. I'm going to solder EC3 connectors on both the battery and the other end of the servo wire.
What connects to what in order for this to work?
Thanks
That could be a problem. To power the servos of a 2S LiPo they must be HV servos (capable of 8.4V operation). Standard servos are only good for around 6V or so and would probably be damaged by a 2S LiPo. If you have regular servos you could use a 2S LiFe which is lower voltage than a LiPo, or you could use a voltage regulator.
On large helis like a 600 it's recommended to take power to the receiver through two JR type servo plugs, each plug is only rated for about 4A which isn't really enough for a large heli.
