Setups Naza keep going into fail safe
WyDiablo
When I re-calibrated and reset everything on the Naza M and GPS Compass and disconnect it from the pc everything is fine. But after a few re-connections (Without pc connection) it will go into fail safe for no reason. I can do a complete reset again with the assistant software and get everything back to normal and after a couple of connections to arms the system its back in fail safe. So is it the naza or the imu that causing it to go into fail safe?
I found the problem I think. I replaced the original rx with a new rx that I got in a week ago. I redid the quad thru the naza software on the pc and re-calibrated everything and the quad is back to normal now. I have rebooted the quad several times now and it goes into the correct sequence to boot the naza and arm the motors.
