smorrison047
Hello all,
I need some help with a revolution problem I am having:
No alarms in GCS, all setups went fine. calibrated and calibrated esc's again to make sure.
When I arm the board, I apply a very slight amount of throttle to get the motors going and all the motors go to near max kv with that tiny bit of throttle.
Again, all systems seem go
The quad is an flame wheel type with built in pc board from HobbyKing
- ESC's are HobbyKing Blue Series 30A stock (are they BLHeli, One Shot or what? I don't know)
- Motors are Exceed RC Rocket series 2215 1950 Kv (model 86MA07)
- Batt is 3s 5800Ah 25c Zippy Compact
- GPS is installed and correctly configured including home location set
- Radio is Turnigy i10
- Receiver is Turnigy ia10
- All systems seem go in radio and receiver and with GCS as well as setups
- Including end points, mixes etc, all zero'ed or -120, +120 respectively
- NO TELEMETRY or SBUS add on's installed
- Receiver is CORRECTLY BOUND and set up
- Radio is set to AIRPLANE MODE
Any help would be greatly appreciated.
Thank you,
Scott
smorrison047
Thank you,
Scott
smorrison047
