Onespeed
I am at the final build stage of my new heli. I have my electronics installed or located where the will be installed and all wires routed. I am a little foggy on setup steps order.. For example I have an Ikon2 that will need to be updated and setup an esc that has to be programmed/ setup. I watched the videos tony made for the new back to basics but was left with some questions regarding updating and getting started with setup because i couldn't physically see the connections made to the Ikon2.* Ok #1 When updating firmware on pc connected to Ikon2.... servos hooked up or no? Power from esc or computer only? Once the Ikon is updated do I just connect all the servos or leave them connected (if that was the case) and connect the esc and power from battery and use bluetooth setup for getting it bound and completed. I know I am making this more complicated than it is ......but this post is basically a heres all this stuff how do you set it up in order without damaging the servos and the esc. I have not set servo center yet as well didn't have a servo tester yet and didn't want to damage digital servos with wrong tester. Any comments about using the esc governor or the ikon's?
electronics Ikon2
RCE- BL80A (rebranded hobbywing so im told)
Dx9 / programmed and rdy for ikon 2 dsmx sat
Thanks for reading my mind barf =)
electronics Ikon2
