Are you getting exited Sam?Looking good
Here are a few shots of what I mean.
<img src="http://www.rc-help.com/attachment.php?attachmentid=4982"/>
Here you can see how close to magnet is to the frame. It hits the two edges going around.
<img src="http://www.rc-help.com/attachment.php?attachmentid=4983"/>
Here you can just make out the scrape mark in the magnet scraping the censor has it passes by.
GABA I just used a drop of ca behind them. I'm going to try smoking them in acitone next weekend to remove them.
I would not try to "smoke" the clutch. That can't be good for your health
I have not seen one with the magnets in the clutch. That is just asking to kill those magnets with the heat from the clutch slipping. But, if that is what the kit calls for, then good deal. I would see if you can get them out, then use a C clamp or something to press them in with some epoxy to hold them. You can also try to put a little air hole in the bottom side of it to let the air and extra epoxy escape while you are pressing them in place.
another question ... what sensor are you using.. ? have you built it the way its supposed to be built? let me know if you need a pre built sensor.. I got one lyiong around.. it should be on a stiff carbon mount, epoxied and ziptied and the "sensor" part is not on the top but on the side long part.. hopefully you know this information .
