Troy Flamisch
Hi,
Just a question regarding head set up. The main shaft will go approx 23mm into the main rotor housing however it only requires to go 5mm to line up with the hole on the housing. I know a bolt goes through that and clamps the housing onto the shaft but is it correct only that much of the shaft is in the housing. I have the correct length linkage rods being 39mm. Also does the swash driver then clamp flush underneath the housing? When I look at the photo on the banggood site I can see a gap between these?
