Yes to get the max power out of that small engine, you should use 30 percent. I run 30 percent too..
and I know y'all have a throttle hold curve.. in my radio just like marius said, I program 7.5 percent on the hold to make it idle.. and to kill the engine either I pinch the line, or I use the trim in normal mode. My trim on the radio for throttle is mechanical.. for the reason it makes it easier to kill engines. As I dont have a throttle kill switch like I had on my DX6i.. i dont know if dx8 has it or not.
If DX8 has a kill switch then I would program the HOLD to wherever the engine idles, barely moving the blades if at all. The percentage might vary from mine to tony's to yours, but that doesnt make a difference. you need to start small .. and increase the percentage to make sure you dont start too hot.
With Ikon you wil have to calibrate throttle end points, so wait till that is done to set anything up anywaz.
People debate on pinching the fuel line. Some say its good to leave some fuel in there, so kill it with throttle kill switch or trim. Some say it is not good at all the pinch becasue its stresses the bearing. Some say it is good to pinch as you empty the fuel out of the heli and prevent a hydrolock next time you fly, and blah blah blah..
I pich sometimes.. and kill withtrim sometimes. LOL
Engine is stil going strong.
.. just letting you know, cause these are things you will see pages and pages of debates on
