I have told you what length the wing should be, about 48". What I'm asking is what length the wing actually is. Did you check the prop to make sure it's put on the correct way? Are you sure you are getting 100% throttle out of the motor/ESC? Do you have plenty of elevator travel? When you add full throttle, do you still have elevator and aileron control? We need to know the answers to these questions in order to help you out.
Tony sir, my plane is of v1 type and is according to your v1 pdf plan file. my plane wing length is 880mm and length of plane is 600mm.
ya i checked the prop and it is placed in correct way.
yes i think its geting 100% throttle....
rudder words very well on ground... i can make is take turn by using rudder...
And even elevator is working well.... but dnt know exactly whats wrong with it that it is not able to get in air...
i think my plane body is not correct.. the landing grear is not placed on correct place and may be some more things wrong in that...
so i have started to make another plane according to your v3.1 plan.....
i downloaded v3.1 plan in A4 size paper and the line given in 1st paper is of correct length 12.7cm but 7th page is not being placed in correct and i think the plan in paper seems to be big and dont know what to do...
sir its my request to mention the length n breadth of each parts and of each lines... so that it will be easy for beginner like me to build it properly and correctly...
