DMartin_nj
Tony,
Thank you again for all your help. You cannot imagine how enlighting it is to have a place to go for help for New commers (to Heli's that is).
Just getting my Dynam E-Razer going again after 5 years. Back then I had the TH9X and lost 1 heli after 50 foot out. Now, with an AWESOME tx, I am ready once again. No worries when I get out there... Whewww.... Not such a noob this time around because I have some experience under my belt. When I starting flying Heli when just learning, putting away all things RC to save money for a while, you tend to loose a lot what you "just" learned. I have more confidence this time around but still learning. Im sure I will pick things up quickly and already have. I had to put the training landing gear back on because I was too nervous. I basically have to teach myself all over again. On that note....
On a side note, I know Im not in the correct form for this topic:
I took my heli to work to mess with it on my lunch break... I noticed with the new radio system after plugging in the GYRO, the servo "twitches" back n forth... It did not do that on the old radio system. I am wondering if this is another issue with old electronics on new radio systems. When I get the speed up, the tail goes back n forth pretty fast, about 2 inches each way guessing. You can hear the air in the tail blades like the main blades on a hard maneuver. It is a possibility I will have to purchase a newer style GYRO for a flybar head system.
Okay, back to the DX8G2 settings:
Keep in mind Im still learning heli's and this radio...
FUNCTION LIST
servo setup:
Travel:
Trottel: 150 100
Rudder: 70 70 (to keep it from pushing too far n burning out the servo)
D/R and Expo: (unchanged)
Channel: Aileron
Curve 1
Dual Rate: 100% 100%
Expo: 0% 0%
Switch: on
Throttle cut: Inhibited (not setup yet)
Throttle curve: Throttle
Hold: 0% 0% 0% 0%
Normal: 0, 25, 50, 75, 100
Mode 1: (unsure here Im testing) 80, 80, 80, 80
Mode 2: (not set yet) 0, 25, 50, 75, 100
Pitch Curve: Pitch
Hold: 0, 25, 50, 75, 100
Normal: (your suggestions I found in a post) 45, 47.5, 50, 75, 100
Mode 1 and 2: (not setup yet) 0, 25, 50, 75, 100
Swash Plate:
Ail: +60
Ele: +60
Pitch: -60
Expo, E-Ring, Ele Comp: Inhibited
Gyro and Governor: Inhibited
Nothing in tail curve, I do not understand all this TX has to offer yet. If there is something I am missing and you need, please let me know.
FUNCTION LIST
servo setup:
Travel:
Trottel: 150 100
Channel: Aileron
Curve 1
Expo: 0% 0%
Switch: on
Hold: 0% 0% 0% 0%
Pitch Curve: Pitch
Swash Plate:
Ail: +60
Ele: +60
Pitch: -60
