Flight Controllers Omnibus F4 Betaflight Setup
If you have a physical plug to plug the satellite into, then definitely do it that way. I didn't have that plug as you can see in the pictures above even though the layout pics show it is there. Maybe this is just my board, but I had to solder it directly. Which turned out not to be a bad thing since I had this short little satellite cable that I had cut previously lol.
I do believe the satellite ports are on UART6, but also try UART3 as well. Make sure to go into the receiver tab and set it to Spektrum and then set the type to 2048, not 1024.
I have to ask, Have you went through the bind process and bound the satellite to your Tx? You can do it with a separate Rx or you (I think) can use set spektrum_sat_bind command in the CLI. And also, again I have to ask, did you turn on the serial rx in the config menu? Again, just trying to cover all bases here.
I was able to get rx working by reflashing the firmware, and flipping through the uart ports until UART 1 worked. I have movement in the rx tab now!
Sorry to dig up an old post, but I have this FC & this thread is the closest I can find to a wireing diagram.
I've got it up & flying, but want to get the battery voltage displayed in the OSD. I read connecting the vbat wire on the plug puts the battery voltage through all the 5v pads. Is this true?
Give me a little bit. I just pulled this quad back out and I'm going to hook up some wires to see if I can get it to work. I would rather blow mine up than yours. Like you say, information on this board is few and far between. I will let you know in a little bit.
Okay, I have confirmed what I thought to be true. You just run a wire from your positive (red) battery wire to the vbat pad. This will NOT push full pack voltage (on my controller, you could have a different one) to the 5v pads. I checked this with a volt meter. If you have the same board as the one in the pictures in the first post of this thread, then I'm pretty confident that it will work just as I have tested it. Let me know how it turns out, just use caution and take off anything you are worried about and test the pads with a volt meter before plugging anything in.
Thanks Tony, I'll let you know the outcome & may even produce a schematic for this FC, showing how I've wired it, to help anyone else in the same position. Seems like a good little cheap FC.
Only if you soft mount it. There is a reason this quad has never seen air time on video. The gyros are just way too sensitive.
Hey there Tony. Both my fossil 180 and 210 have the Omnibus F4V2 FC on them. Maybe because it's the V2 version but mine are mounted hard and the abuse I put them through don't seem sensitive at all. Especially the 180 because I use that one for free style and it has the tendency to visit the ground often. Like I mention, it might be because of the V2 version, I don't know.
Yea, this one is the V1 and it just freaks out after about 5 seconds in the air lol.
I heard the same thing about the V3 one. They have ones up to V7 but I'm sticking to the V2 FC. There're easy to setup and I haven't had a problem with then beside the one beeper connection that's not working on the 180 but the 210 one works fine. I gave up on putting the beeper on the 180. I do have 3 other Omnibus F4V2 FC on stand by...just in case :eek:. I sent you one of those F4V2 FC that I had problem connecting to beta flight. If you get that one working...give it a try. I think you will like it :).
I have all 3 of the boards sitting here on my desk. Trying to get caught up on everything and once I do, I will be looking into those boards.
Hi guys, does anyone know what the CRNT pad is for? is this perhaps for the current directly from the battery? so you can see your current on the OSD?
I think on the newer FC's its call vcc
VCC is your main voltage in. CRNT should be Current as you state. Can you post what board you have so that we can look at it? They make changes to these boards all the time and I like to look at them before speculating. If you can post a link to the one you have, it would help.
So I want to see the voltage from the battery on my googles and i think this is the pin i need to soldier from the pdb. Im just not sure if its 5v or directly from the battery (vbat+ eg 15v if im using a 4 cell lipo). Ive got the exact board in this thread.
Ah okay. In that case, that pin is for a separate board. You should have current and voltage options in the OSD menu in betaflight to show in your goggles.
Not that I"m aware of. I know I have never used that port before and if I remember correctly (it's been a minute since I played with this board lol), everything should be accessable automatically through the menu for OSD. If not, I will see if I can dig this board out and plug it into my computer later one if you can't get it to work.
