Well, it has been about 4.5 years since I posted in this thread. I'm sure there is another thread on this computer, but I can't find it lol. If you know where one is, post a link to it and I will move this info to the new thread.
So an update on this poor computer. I am still running almost everything that is posted in the first post of this thread. I have replaced the 120GB SSD with a Samsung 850 Pro 1TB SSD that was donated to the forum just for this computer. Not sure if the member wants to be mentioned, but if he does, he can post in here. The 120GB SSD went into my grandmothers computer that had a very slow HDD in it.
I have also had to replace the GPU in this thing. The 560Ti started giving me issues and then just completely died. I'm sure you all remember me posting that I was testing this card and had my finger get into the blades of the fan running full blast which sprayed blood everywhere. It is without a doubt my worst injury from a computer lmao. I didn't think I was ever going to get the bleeding to stop. If you don't know what the blades on this GPU look like, click on the link in the first post and go check it out. They are pointed and it was running at full speed which is friggin fast. My finger stopped the fan and broke the blade off that went into and through my finger.
I still have not fixed that front top fan that was not working in the video above lol. But I'm about to have to do some work on this computer and when I do that, I will take that fan out and try to fix it. It has multiple wires on it and it takes some work to get them out hence why I have not pulled it out yet. I am thinking about getting a smaller case since I no longer have any HDD's in this computer. I am instead using a NAS (Network Attached Storage) for all of my storage, but with this 1TB SSD I get speed and capacity. So with that said, I just need a case that will house the ATX motherboard, my new GPU (forgot to mention that above, I will talk about that here in a second), a 280 Rad (the reason I'm making this post actually lol) and my SSD. That is all the space I need.
So about the GPU. When my GTX 560 Ti died, I ordered an MSI GTX 1050 ti. I really wanted to get at least a 1060 but I just flat didn't have the money at the time to do that. So I had to settle for the 1050 Ti which is still twice as good as what I had before. This GPU has proven to do just about everything I want it to do without breaking a sweat, except for playing iRacing on triple screens. It is just a little stressed when I do that, but I can do it. So I'm liking this GPU but I"m still actively looking for a 1070 or 1080 to replace it so that I will quit stressing it in triple screens running high frame rate games.
So onto the reason I'm making this post in this thread. For some reason, I decided to check on my CPU temps. I had not done this for a very long time because I'm not running an overclock on this i7 960 which is a very old CPU now. And with the introduction of Spectre and Meltdown, and the only fix is to close the cache on the CPU which slows this chip way down, I need to overclock it. I'm pretty sure this is the reason I checked on my core temps because I needed to know what the temp was (same cooler as in the video BTW) so that I would know what kind of temps I would be looking at after giving it a good OC. Well, my computer, at IDLE! Is running 60ºC!!! Holy hell!!!
I was not expecting to see temps like that. 50ºC, okay maybe, it is on air with a horrible fan, but over 60 is not acceptable. how that was a peak temp, and it usually stays around 55, but still, that is way too hot if I want to overclock this thing.
I own a 360 Radiator, I own a res for the water level and I even recently received a copper water block that I ordered after a couple months of waiting. All I need is tubing and a pump, and to make the 360mm Radiator fit in this case that was not designed for it. I have 3 fans on the front of the case, but they are case flow fans and not static pressure fans that you need on a Rad. And the pumps out there that are half worth a crap are about $100!!!
So I started looking at some AIO's (All In One's) that have the rad, tubing, pump and block all in one. Most of these are about $150 but Newegg had a sale going on for the Corsair H110i Extreme which is a 280mm Rad (dual 140mm fans instead of the 120mm) which gives me about 30% more surface area compared to the same thickness 240mm Rad. And, I have dual 140mm fans on top of my case where I am pretty sure I can fit this Rad, but I can NOT fit a 240mm where the back two fans are because of the tanks on each end of the rad.
I'm hoping to get my idle temps down into the 30's with the AIO and man is this going to free up a LOT of space inside this case. This thing is going to look empty! No HDD's, no massive air cooler, so I no longer have the need for a case of this size anymore.
If any of you have run this rad before, let me know what you think. The AIO is a maintenance free water cooling solution that never requires filling and it comes with a 5 year warranty on both parts and labor! I figure that is well worth the $95 I paid for this thing. I have even seen videos where they state "unless you are using a Ryzen 1700X or above or something like a 7700K, chips that produce a LOT of heat, then don't waste your money. This jackwaggon was basically saying to go with a cooling solution that would just barely work on your system saying that all people really need is a 120mm radiator and they would be fine. Um NO! I'm going to go overkill so that I have more head room and I keep it cooler, thank you very much! lmao.
And just an FYI, this i7 960 is factory clocked at 3.2GHz and I plan on putting a 1GHz overclock on it to try and overcome those two issues and how slow they have made this computer. Hell, I could put a 4.5GHz clock on this thing with 1.4 volts, but that would be pushing it just a little farther than I would like. I would really like to just build a new computer, but at this time, I just can't afford it.
But if anyone knows of a good case that will fig a 280mm Rad and an ATX motherboard, let me know. You can't buy the 1366 motherboards anymore otherwise I would just look for a new board in the micro ATX form or even a mini ITX for an even smaller case. So definitely let me know if you know of anything. And also let me know if you would like to see the install of this radiator!
Oh and one last thing. I put this air cooler on here back in 2012 when I built this computer and it has never been removed. So it is quite likely the thermal compound that is on it is completely rock hard and that could be the reason for the high core temps. I guess we will find out next week when I receive my new radiator
