I'd be putting it in a Blade 550X.
This thing is gonna cook.
Problem is stock gearing is setup for 1350ish kv motors. They have some higher tooth count pinions, up to 16T, but I need 17.3 to get to the same headspeeds I'm running now. So I need to source a smaller tooth main gear. Looking like Lynx has an option for me. 133T main gear with 13-17T pinions. I could go with 14 and get a small bump in headspeed so I'd go with that.
I need to measure how much space I have in the canopy to fit the thing, though. I think the KDE is narrower than stock, but it is almost a cm taller. Also need to make sure shaft length is right.
Did you chop the shaft at all? Looks like the KDE motor stock length is over what I need so I'd be chopping, just need to make sure you didn't do it already. If you did, how much is there below the bottom plate of the motor?
Also is there a collar at the base of the motor on the shaft, or does it use a snap ring?
