Harford
I am setting up my Trex 450 after upgrading the BeastX firmware to V5.2.2.
I have a problem achieving zero pitch at mid stick. With the blades positioned diagonally to the longitudinal axis, I have 0 degrees, with one reading and negative 2.3 degrees when I rotate the blade 180 degrees. I have the same result with both blades. I am not sure how to adjust this.
The swashplate is level. Any help would be much appreciated.
Many thanks
Michael
Many thanks
Michael
