Thanks Eyestation , I've been adjusting things for a couple of days now and it flew ok this morning but I felt it should be more stable! So carried on adjusting , now I can get the perfect 0 pitch -10.1 +10.2 but only with both blades in the same position , ie with the blade pointing out to the right , then I have to swing the left blade round to point out right also , they are both perfect like this but if I leave the left blade pointing left or even swing the right blade to the left the pitch is wat of , I fact I don't even get full adjustment with the blades pointing out to the left.??? Confused big time
If you are getting uneven pitch from the left to right hand side, then it could be that your swash is not level in the aileron axis. This would cause you to be able to set it up perfectly on one side and not the other. This could also be the case for front to back, if the elevator axis isn't level.
Double check you swash is perfectly level. Its the only thing that could cause this, unless something is bent in the head.
