Westy
LEGEND
the Reason it is all not going to the perfect plan ... is because the head is not genuine align .... and there fore the design dimensions have gone a little haywire as part of the copying process.....
you will probably find that as it was with -3 to +10 .... equates to about low stick -5 to +8 high stick ... which is learners sports pitch range anyway ... would have worked fine for hovering and sports...... but not 3d.
you could have then tamed it down in normal mode to give you +7 at high ..... +5 at mid and then +2 to +3 for low ..... so that the heli will not plant into the ground as they do with learners due to over compensating and panicking and slamming the collective all the way down .....
