Harford
I am starting the process of assembling my Trex 700E FBL. I want to check that the thrust bearings are correctly assembled and greased. How can I remove them (and the radial bearing) from the blade grip please without damaging anything. They appear to be a very tight fit.
I have read that placing the blade grip in the oven for a period (eg. 15min at 250F) is a solution.
I would very much appreciate some advice on this.
Thank you
Thank you
