I have a DJI F550 naza hexa copter and the motor spindles are 3.17mm. With the adapters that come with the props all I need to worry about is what size prosp to buy correct? The adapters will reduce to whatever size collet screw that I am using correct? By the way the screw size is 4.80mm. The funny thing is that my props right now have a bottom and top hole that measures 6.20 and 5.22 should they not both measure that same size? You can tell by my question that I am one lost guy.
Thanks for any hlep guys
WyDiablo
WyDiablo
