Plug in the USB, go to the motor tab and raise the master switch all the way up. Plug in the battery and listen for the first set of beeps. When you hear them, lower the master control all the way down. This should calibrate all of the motors.
That's what He just did in the video.
Something very strange going on.
Somehow the quad seems to be being powered up by USB.
Those motors
should not move at all when you move the the slider in the motors tab unless you have a battery connected.
I have some ideas so bare with me and try a few things.
Hook up usb and use a volt meter to check if there is any power at the battery plug, if there is you have a problem that needs to be sorted first before you do any damage.
(If it's not already to late)
Do you arm by switch or stick command?
Also, do you have oneshot enabled on configuration tab.
What version is the naze board.
Are you sure the ESCs are simonk or are they called simon series ESCs., what brand are they?
