Quad Sam's QAV500 build
YEAH!!! It is here WOOHOO!!! I ordered it on Nov. 26th it just got here this morning....
Man can't wait to get this thing hooked up and in the air.. I will also have GPS capability once i can afford it software is already installed 1 less worry plus i got the oled screen to be able to change settings at the field... As soon as i can get it all setup will be in-flight video via my dice cam already till i can afford a gopro3
have to solder up power wires on the power board bind rx and get motors connected correctly should be good had to 1 of my 3s pack couple days ago down to only 1 lipo for it now my other 2 7.4v lipo packs and my on big 22.2v lipo pack are all starting to puff too so will be down to only 1 pack soon this sucks...
I just painted my quad what do you guys think
I am finishing up the power board and re-solderingthe multiwii board
Looks good , but The front arms look to be a bit long.
Look at this Spider Quad, you can see that the arm size front and back will make a square.
The back arms will always be 1.5059 * the front arm size.
if front arms are 9" it would be 9" * 1.5059 = 13.55" or just 13.5"
Very nice looking Wii board...
The back arms will always be 1.5059 * the front are size.
are you talking to me craig???/
the back arms are 12" and fronts are 10" according to the calcu;ater for the backs to be 12" i have to cut the front to 8" would that be ok with 11" props???
This is for Lee.
You can see the red plugs are for power and the black servo plugs are the camera.
Then I have one y harness done for the camera. I have to get parts for the power y harness. I'm not hooking them up together yet though. Till I get the wireless tx working. But I'm thinking that there is something wrong with the RX in the goggles!
Ok if you remember i asked you how you are getting the 12V for the camera. Well the chinese TX you have provides 12V to the camera, but the Fatshark only puts out 5V. So if you are trying to power the camera from the Fatshark TX it won't work. I have a separate Voltage regulator to provided the 12V to the camera.
My power for the TX comes straight from the frame. The signal wire goes to the camera and the ground wire goes to the Voltage regulator. The camera ground wire and positive wire go to the Voltage regulator.
Not sure if this will help you or not.
I just looked it up on the web sight. My camera dose require 12V to operate so I'm going to go make a harness and try it.
Lee your the MAN!! You hit it on the head! I hooked up 12v to the camera direct and what do you know video! Lol. All is working has it should! Thanks a lot Lee. All that's left now is zipping up the wiring harness and I can go fly her next weekend! YE HA!
