Protos are a nice heli .... setting it up right ... is the first hurdle ..... if you want to reduce the chance of damage ... go FBL and IKON and you can set up the auto correction feature and grow into your heli ... as you get better ... you relax that auto correction to a point where you no longer need it!
Lee and others have the IKON .... and they Rave about it .... I am going to get one as I am now getting heavily into 3d flying .... the Bail out feature is going to save my bacon! IKONs RULE!
Honestly .... you will thank yourself for listening as the first bail out or auto correction the IKON will do for you ... .will save you more than the added cost of the FBL and IKON .... in repair build money and time to rebuild!
The most frustrating part that I and others have experienced is that you seem to be spending more hours working on them than flying them.... then you cross the threshold and it is the other way around . IF IKON FBL controller had been around when I started .... I honestly think I would be strides ahead of where I am.
Hope that all makes sense!
I can do that with my 450 (but i cant hover right side in)
ARe you talking of nose Right? if so....... try this.....
If you can fly Tail in ... you can do nose right!!!!
1. PLace the heli on your right side tail in ..... about 6 feet in front of you....
2. Fly it tail in ...... then turn it nose right (rudder to 3 o'clock then neutral again) then turn yourself to your right (move your feet too) .... you are now tail in .... slowly turn your body back to where you started ... and if you freak out .... turn back toward the heli (3' oclock again) to get it at tail in again ....
with practice you will get comfortable with it .....
if you prefer the heli nose in ... then do it the other way with your heil on your left ... and face it so it is nose in....
hope it helps. Cheers
