We got the new castle ESC and the KDE Direct 450XF-3500 High Performance Brushless 450 Class Motor (3500kV) both running smoothly. We did run into a conflict between the Castle ESC and the Spektrum/BeastX receiver that fakes out the low throttle setting. One of the guys at our field had a procedure to set throttle end points that keeps the castle happy and everything works great. I will cut/paste it below. It is long but it works great.
Setup Endpoints for Caste ESC and AR7200BX without needing separate power supply
Here is a procedure that will work to setup your ICE ESC with your AR7200BX, without using a separate power supply. This procedure was done with a DX7 radio, so make adjustments where needed for your radio. This procedure does not care if your equipment is brand new or well used, previously calibrated or not. It will work. This assumes you are running the ICE in governor mode. You may or may not use Auto Rotate feature, that’s up to you. You may or may not like the Fail Safe feature, but it matters not. It is there, so you must deal with it. Follow this procedure step by step, and it will work every time. Here we go:
- Before you start, remove your rotor blades and tail blades!
- Set Throttle Curve for ST-1 to (70,INH,70,INH,70)
- Set Throttle Curve for ST-2 to (100,INH,100,INH,100)
- Set Flight Mode to Norm
- Set Throttle Curve for Norm to linear (0,INH,50,INH,100)
- Adjust Travel Adjust for Throttle to H=0, L=0
- Battery unplugged
- Radio off
- Put Bind plug in Bind slot on AR7200BX
- Plug battery in
- Hold down Bind button on back of DX7
- Continue to hold down Bind button while turning on Radio
- Continue to hold down Bind button until flashing light on AR7200BX (or on satellite) turns solid (this light is down by the servo plugs)
- When light is solid, Bind is done
- Remove Bind plug
- Unplug battery
- Radio off
- Radio on
- Plug battery in
- Move throttle stick to High (full throttle, all the way up)
- Raise Travel Adjust H until the motor beeps
- Raise Travel Adjust H two more clicks
- Move throttle stick to Low (zero throttle, all the way down)
- Raise Travel Adjust L until the motor beeps
- Raise Travel Adjust L two more clicks
- ICE ESC is now calibrated for throttle
- Set Throttle Curve for Norm to (0,INH,0,INH,0)
- Flight Mode is still in Norm
- Unplug Battery
- Radio off
- Plug battery in
- Remove Bind plug
- Unplug battery
- Radio off
- Radio on
- If you are NOT using Auto Rotate feature, set Throttle Curve for Norm to (30,INH,30,INH,30)
- If you are NOT using Auto Rotate feature, set your Throttle Hold to 0
- If you are NOT using Auto Rotate, you are done
- Everything after this step is only needed if you are using Auto Rotate feature
- Throttle Curve for Norm should still be set to (0,INH,0,INH,0)
- Flight Mode still in Norm
- Throttle Hold is OFF
- Set Throttle Hold to 0
- Plug in Battery
- Wait for ICE to initialize
- Throttle Hold ON
- Raise Throttle Hold setting until the heli starts to spool up
- Lower Throttle Hold setting until the heli stops
- Unplug Battery
- Radio off
- Plug battery in
- Throttle Hold OFF
- Continue to hold down Bind button while turning on Radio, after turning on radio, immediately switch on Throttle Hold
- This bind with Throttle Hold ensures that if you have a signal loss the AR7200BX will output your Throttle Hold setting and not your Low Throttle setting. That way when the signal comes back, the ICE will quickly spool up to speed again.
- Remove Bind plug
- You’re are done
- Battery unplugged
- Radio off
- Plug battery in
- Remove Bind plug
- Unplug battery
- Radio off
- Radio on
- Plug battery in
- Unplug Battery
- Radio off
- Plug battery in
- Remove Bind plug
- Unplug battery
- Radio off
- Radio on
- Plug in Battery
- Throttle Hold ON
- Unplug Battery
- Radio off
- Plug battery in
- Throttle Hold OFF
- Remove Bind plug
- You’re are done
