Sidik Hartono
hello Tony, nice to meet you. I often see your YouTube videos, and the content is very helpful for us as beginners.
There are a few questions I want to ask,
as you explain in the video swash plate setup Trex 450
All swash plate & main rotor head must be leveling ... For those of us as beginners, just learning hovering, the pitch degrees setting is at 0-8 degree, without minus inverted.
1. Then the leveling setting on the mid-stick is: 4 degrees Is it true?
2. The servo horn 90° starting from lower stick or starting from the middle stick?
Thank you for your kind
