hi thinking ahead if the new balanced charger does not fix the problem and I have to get a ESC any suggestions on what I need to look for please ?
I have a BL speed controller 20A for the main motor and a 5A for the tail , having no experience of ESC I am presuming there are 2 of these not one with both built in ?
Both motors are brushless and I have both of the Nine Eagles part numbers but these are impossible to find .
NE252426 MAIN 20A
NE252427 TAIL 5A
Any advice would be really appreciated as I really haven't a clue with the ESC .
I can physically change the parts but will I need to set them up or are they plug and play ?
thanks again for your help.
Look for potential binding that can cause an increase in your power load first as it is the more likely cause. I'd probably suggest the main rotor first since it will have the linkages. I also mentioned to look at the tail if it also has linkages but I didn't think it would.
I can't directly answer your replacement ESC question. Your heli has parts I'm unfamiliar with as will most people on this forum since we tend to use hobbyist grade equipment most of the time.
Toy grade RC equipment often have proprietary components and often can not just be switch out with more common ones. As I mentioned, the one you have is in the upper tier of what I call toy grade and it actually has replacement parts available which many of the cheaper toy grade stuff doesn't have. Still, I'm not sure if the more common parts will work in your heli but I can mention a couple of things.
ESC's come in two types... One type for brushed motors and one for brushless motors. Brushed types will have two power leads going to the motors, brushless types will have 3 power leads. Brushed motors are polarity sensitive so you must put the black ( negative ) and red ( positive ) wires to the proper wires on the motor or it will run backwards. Brushless types do not have standard colors for the wires, if you hook them up and the motor spins backwards, you just switch any two wires around to make them spin in the right direction. Most of the toy grade equipment will use a brushed motor since they are cheaper to make.
I would do a google search for the exact make and model of the ESC's your heli has. Being an older one, availability is going to be an issue. They may have also updated the ESC with a newer model if they made that model for any length of time. So if you find replacement parts, they may be a different model number if they got an update. I did a search earlier and I think I saw some available but I didn't "vet" my results. I also didn't worry about what country they were available in when I searched.
