Tasajara
I guess if most ppl see what I fly on here know I like spider quads...
That said... here is one I am building from scratch that is 25% bigger frame than my others.
The first thing I started with was my motor mounts.
BlueSkyRC.com sell some for a Mega Quad that use 1/2 booms. So I though I would give them a try.
Here are a few pics, you can see the size difference over the standard motor mount.
I cut the landing gear off of the mount because I was going to use T-Rex 600 gear cut in half.
Now onto the frame plates... Made a little pattern to go by and started cutting.
Here are my top and bottom frame plates...
Now I have to lay out some guide blocks for my boom to slide in once the 2 sides are glued together.
And cut a few boom sticks, in the pics the booms were a bit longer at first.
But once I played around with the size I wanted I ended up cutting them down to
10" on front and 15" on the rear.
Here are a few more pics.
I will have 3mm allen bolts holding the booms in place along with a few wood screws.
